跳转到主内容
How to Fix a Brazilian Hammock
你所需要的
  1. How to Fix a Brazilian Hammock, How to Fix a Brazilian Hammock: 步骤 1 中的图像 1,1
    • Place the hammock on a flat surface.
    • Use scissors to cut the frayed ends from the damaged area.
  2. How to Fix a Brazilian Hammock: 步骤 2 中的图像 1,2 How to Fix a Brazilian Hammock: 步骤 2 中的图像 2,2
    • Align both sides of the tear leaving a quarter-inch gap between both sides of the tear.
    • Use safety pins to temporarily hold both sides of the tear together.
  3. How to Fix a Brazilian Hammock: 步骤 3 中的图像 1,1
    • Cut a patch of the Ripstop fabric slightly larger than the tear.
  4. How to Fix a Brazilian Hammock: 步骤 4 中的图像 1,1
    • Place the fabric on top of the tear and using safety pins temporarily hold the fabric to the hammock.
  5. How to Fix a Brazilian Hammock: 步骤 5 中的图像 1,3 How to Fix a Brazilian Hammock: 步骤 5 中的图像 2,3 How to Fix a Brazilian Hammock: 步骤 5 中的图像 3,3
    • Be careful with the sewing needle. The end is very sharp.
    • Thread the needle and tie a knot at the end.
  6. How to Fix a Brazilian Hammock: 步骤 6 中的图像 1,3 How to Fix a Brazilian Hammock: 步骤 6 中的图像 2,3 How to Fix a Brazilian Hammock: 步骤 6 中的图像 3,3
    • This step requires basic sewing skills but is easy to accomplish with time.
    • Use the threaded needle to sew from the bottom of the patch up and around the perimeter.
    • Make sure the needle and thread go through the patch and existing hammock material.
  7. How to Fix a Brazilian Hammock: 步骤 7 中的图像 1,1
    • When finished tie a knot at the end of the stitch.
    • Make sure the knot is large enough, so it does not slip through the stitches.
  8. How to Fix a Brazilian Hammock: 步骤 8 中的图像 1,2 How to Fix a Brazilian Hammock: 步骤 8 中的图像 2,2
    • Remove all the safety pins and appreciate your work.
结论
This guide is now completed, enjoy your newly restored hammock.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 110
