跳转到主内容
How to Exit ZTE Max XL Field Test Mode
  1. How to Exit ZTE Max XL Field Test Mode, How to Exit ZTE Max XL Field Test Mode: 步骤 1 中的图像 1,1
    • Field Test Mode (FTM) can be useful if you perform tests on signal strength, but for most users it prevents some applications to run correctly.
    • The phone screen will display FTM when in the mode.
  2. How to Exit ZTE Max XL Field Test Mode: 步骤 2 中的图像 1,1
    • Hold down the power button for 10 seconds to turn off the phone.
  3. How to Exit ZTE Max XL Field Test Mode: 步骤 3 中的图像 1,1
    • Press the power button until your phone responds to power on the phone.
    • To assure your phone does not stay in FTM, DO NOT press the lower volume button. Pressing of the lower volume button is the reason your phone enters FTM.
  4. How to Exit ZTE Max XL Field Test Mode: 步骤 4 中的图像 1,2 How to Exit ZTE Max XL Field Test Mode: 步骤 4 中的图像 2,2
    • If the phone is still in FTM after the reboot, make sure the lower volume button is not stuck.
    • After the button is unstuck, repeat step three.
终点
2等其他人完成本指南。
Olivia Wolf
于02/15/18注册
1,400 声望
创作了5篇指南
团队
UW Stout, Team S8-G2, Ogden Spring 2018 UW Stout, Team S8-G2, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G2
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 18
总计 849
