当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Power on your Mac and launch Terminal.
To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return].
Your [return] key may also be labeled ⏎ or [enter].
If you are prompted for an administrative password, type the password and press [return].
Your password will not be displayed in Terminal.
You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
Remember, you must still disconnect the battery before servicing internal components.
When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
sudo nvram AutoBoot=%03
Press [return].
Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
