跳转到主内容
How to Change Mercedes W123 Power Steering Fluid and Filter
你所需要的
  1. How to Change Mercedes W123 Power Steering Fluid and Filter, How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 1 中的图像 1,1
  2. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 2 中的图像 1,3 How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 2 中的图像 2,3 How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 2 中的图像 3,3
  3. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 3 中的图像 1,1
    • With the lid removed you can see that this fluid is a bit low, and is also very dark/dirty.
  4. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 4 中的图像 1,2 How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 4 中的图像 2,2
    • Remove the nut holding down the spring and plastic retainer, if present. On some cars, there is just a spring as shown in the second picture which should be removed.
    • The nut on this car is a 10mm.
  5. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 5 中的图像 1,1
    • Now use your fluid extractor, or turkey baster (never use it in the kitchen again!) to remove enough fluid to get easy access to the filter.
    • Dispose of the fluid in your drain pan.
  6. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 6 中的图像 1,1
    • Remove the filter using a pair of needle nose pliers.
  7. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 7 中的图像 1,3 How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 7 中的图像 2,3 How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 7 中的图像 3,3
    • See how nasty this is? This may be the original filter, almost 30 years old...
    • Nice fresh filter picture, ready for install.
  8. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 8 中的图像 1,1
    • With the filter out, you can remove the remainder of the fluid in the reservoir.
  9. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 9 中的图像 1,1
    • Install your new filter. Install it with the holes facing upwards, as shown.
  10. How to Change Mercedes W123 Power Steering Fluid and Filter: 步骤 10 中的图像 1,1
    • Replace the spring, retainer and nut over the filter and tighten down. The spring should still have some room to expand and contract but should be snug.
    • Fill the reservoir to the bottom of the metal rim around the top of the pump housing.
    • This car is getting power steering fluid, instead of automatic transmission fluid. Both are OK. The power steering fluid is clear.
    • Now, turn on the engine. Be sure the car is in park or neutral first. Turn the steering wheel left and right, as far as it will go, a few times to get out any air.
    • Top off the fluid as needed. Never let the pump run dry.
    • If your fluid is very dirty, simply repeat the process of sucking out fluid, putting the filter back in, filling the reservoir, and then running the engine and turning the wheel until it looks clean.
结论
Finish by re-installing the cap and taking it for a test drive.
21等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,040 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
14条评论
I find this tutorial so simple to follow. I prefer images and text to video. Well done!!!
Holden Belmont - 回复
Holden, I am glad it was helpful! I agree, I usually prefer good pictures and text to a video - no need to rewind when you miss something.
Nicolas Siemsen -
Agreed. Very well done !
susan vernon - 回复
Thank you so much for your detailed guides! What sort of symptoms could we expect if the power steering fluid or filter need replacing?
Angel Jon Camama - 回复
This was so professional; technical writers take notice!
Brian Graham - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 28
过去 30 天: 147
总计 24,786
