跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Learn to check the power steering fluid level on your Mercedes W123 to keep that boat turning smoothly!
工具
没有特定工具。
配件
  1. Your power steering fluid reservoir is located within the pump which is on the right side of your engine, when facing it from the front of the car. In the U.S. this is the driver's side. Attached to it are the following components:
    • Your power steering fluid reservoir is located within the pump which is on the right side of your engine, when facing it from the front of the car. In the U.S. this is the driver's side. Attached to it are the following components:
    • Pulley and belt
    • Hoses that connect to the steering box
    • Cover
    • To check the level of power steering fluid inside the pump's reservoir the cover will need to be removed.
  2. To remove the cover begin by loosening the retaining nut. On this car it is a metal wing nut, but on some W123's there is a plastic thumb nut.
    • To remove the cover begin by loosening the retaining nut. On this car it is a metal wing nut, but on some W123's there is a plastic thumb nut.
  3. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  4. As the nut loosens use a second hand to hold the cover down. There is a spring under the cover that will force it up and make it harder to remove the retaining nut.
    • As the nut loosens use a second hand to hold the cover down. There is a spring under the cover that will force it up and make it harder to remove the retaining nut.
  5. With the nut removed slowly and carefully allow the spring to push up on the cover until the tension is removed.
    • With the nut removed slowly and carefully allow the spring to push up on the cover until the tension is removed.
    • Remove the cover and set aside someplace clean.
  6. With the cover removed you can now observe the fluid level.
    • With the cover removed you can now observe the fluid level.
    • The level should reach the small ledge at the back left of the reservoir.
    • While the cover is off you can also check the condition of the fluid by piping a small amount in to a syringe or turkey baster (used only for automotive fluids - never use it in the kitchen again!) If the fluid looks dark, instead of a clean red, consider changing it and the filter.
结论
15等其他人完成本指南。
Nicolas Siemsen
于2013年12月06日注册
33,383 信誉积分
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
293 名成员
创作了928篇指南
This perfectly put together guide, made this process absolutely effortless ! Thank you
Sandra - 回复
The indicator marker inside the pump reservoir is to measure fluid at hot (operating ) temperatures only. When cold or ambient the level should be between 6 and 8mm below that marker. The spring in this pump is missing the detent that holds it down. The spring is not meant to be held down by the reservoir cap.
Stephen Duclos - 回复
Thanks a lot for sharing your knowledge and may God bless you. Take care.
Abdoolah Khodabocus - 回复
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 34
过去的30天: 216
总计 11,642
