跳转到主内容
How to Calibrate an Optical Fingerprint Sensor
  1. How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 3,3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
    The Self Repair Assistant is now working on one ui 6.1
    Jayson Chua - 回复
    Je trouve mas l'application
    Oussama Reddaf - 回复
    Make sure to set your phone date to year 2022 before using this app version. If you don't, it will not work and ask you to download the latest version.
    Do not use the latest version of this app as it will ask for Samsung-made battery serial number (really Samsung. copying Apple for this is anti-consumer).
    Peter Chang - 回复
  2. How to Calibrate an Optical Fingerprint Sensor, Install the app: 步骤 2 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Install the app: 步骤 2 中的图像 2,2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
    It says model not supported
    kayceegovender24 - 回复
  3. How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 3,3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 3,3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
    Su s20 con one ui 5.1 viene fuori il messaggio di aggiornare l app
    _matti_ - 回复
  5. How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: 步骤 5 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: 步骤 5 中的图像 2,2
    • Open the Self Repair Assistant app.
    This app fails to open says model not supported
    Jim Donnellon (Truman) - 回复
    I installed the gpt ap but i dont find samsung repair assistant
    Abdallah Sow - 回复
    Model not supported
    Seeking resolve - 回复
  6. How to Calibrate an Optical Fingerprint Sensor, Agree to the terms and conditions: 步骤 6 中的图像 1,1
    • Select "Agree" to accept the Terms and Conditions.
    App open nhi ho raha hai
    Shahid Ansari - 回复
    In galaxy a31 it doesn't work
    Yuvraj Singh - 回复
  7. How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 3,3
    • Select the "Display" icon.
    • Select "Continue" at the bottom of the screen.
    • If you want to perform a battery cycle reset instead, follow this guide.
    • Select "Start" to begin the fingerprint sensor calibration.
    I'm unable to open the application it's not at all opening
    Sam Maaz - 回复
  8. How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: 步骤 8 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: 步骤 8 中的图像 2,2
    • Once the screen turns black, select "Start" again.
  9. How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 3,3
    • Place the white box over the outline near the bottom of the screen.
    • Cover the outline with the side on the box that matches the pattern.
    • Make sure the white box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
    Where do i get the white box?
    Cocoa Tea (cocoa tea) - 回复
    Hi there.
    Currently, the only way to get the boxes is by purchasing the Galaxy Tab S7+ Screen kit. Samsung intends to sell them separately at some point. This guide is only for the Galaxy Tab S7+ at the moment.
    Alex Diaz-Kokaisl -
  10. How to Calibrate an Optical Fingerprint Sensor: 步骤 10 中的图像 1,1
    • Use your finger to press down on the white box.
    • While pressing down, use your other hand to select the "Next" icon near the top of the screen.
    • Continue pressing until the "Calibrating" disappears.
  11. How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 3,3
    • Place the black box over the outline near the bottom of the screen.
    • Make sure the black box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  12. How to Calibrate an Optical Fingerprint Sensor: 步骤 12 中的图像 1,1
    • Use your finger to press down on the black box.
  13. How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 3,3
    • Place the side of the small white box with the grooves over the inner portion of the outline near the bottom of the screen.
    • Make sure the grooves on the box are vertical when placing it on the screen.
    • Make sure the white box completely covers the inner outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  14. How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 3,3
    • Use your finger to press down on the small white box.
    • Continue pressing until "Done" appears at the top of the screen.
    • You may need to reset your device for the calibration to apply.
    Samsung A52 modelinde islemir🥲
    Nurlan esgerzade - 回复
结论
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
40等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
161,939 声望
创作了769篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,409篇指南
22条评论
When I open the app after installation I get this toast message "this model is NOT supported"
My device is a Galaxy A71
Pierre Ehab - 回复
I have a Galaxy A70. "Fingerprint sensor Calibration needed" when I try to turn on Biometric. *# 0 *# says the sensor is alright (everything pass) But calibration = 1
HOW do I calibrate the sensor? The local samsung service center is trash
nombre20 apellido20 -
When I open the app after installation I get this toast message "this model is NOT supported" My device is a Galaxy A52
neskagu nikomu - 回复
Hi there.
Unfortunately, as stated in the introduction, the only device supported right now is the Tab S7+ . Samsung plans to include more devices with time.
Alex Diaz-Kokaisl -
It showed not supported for this model... What should i do next
Salem Ekwuribe - 回复
Sir reset a phone please start up sensor finger please request
Maa Kali - 回复
Please my phone does not support and I done have factory reset but still. Please what should I do??
Bascozar Evans - 回复
App not supported show how raha h
Mohit Saxena - 回复
Hi , is there any app for sm a805f (a80)??
حمید هوشمندی - 回复
What are these white and black boxes? Any info on them would be greatly appreciated
Milo Diazzo - 回复
Did you find anything?
169 assimou -
There are still no more devices than the galaxy s tab..?? I had thought about buying the track gauge.. Does anyone know for sure what devices are supported?
Todavia no hay mas dispositivos que el galaxy s tab..??
Habia pensado en comprar el calibrador de huellas..
Sabe alguien seguro.. que dispositivos cuentan con soporte??
Maribel L.o. - 回复
Hi Maribel.
Currently, only the Galaxy Tab S7 is supported for the fingerprint calibration. Samsung is planning to update this in the future.
Alex Diaz-Kokaisl -
HOW do I calibrate the sensor? The Local service center is trash
nombre20 apellido20 - 回复
How calibrate for samsung s10+ ? because the apps not support fol model samsung s10+
Aldy Mardiansyah - 回复
not support this dive What is the probelem
Babi - 回复
Samsung A51 not support grrrrr
Chris - 回复
Hello my S7+ screen is cracked and have considered fixing it myself, and while looking for parts it seems there is just the glass which is much cheaper and the whole digitizer which is much more expensive. I know without seeing the tablet it would be very hard to tell but does it generally need the more complete digitizer along with the screen or are there times when only the glass imps needed?
MaximusAurelius - 回复
I would just really like to be able to repair this, because the way getting these tablets repaired is almost not viable. The expense make it so buying a newer model is the way to go and I hate how many things have become throw away, and repair a very unlikely route.
Où trouver ces petites boîtes noires et blanches ?
Benn - 回复
It doesn't my galaxy A50
EnockEffum - 回复
hello ..i have recently changed my Samsung A50 screen bt it ame back when the fingerprint isn't working
It shows " fingerprint calibration needed , contact customer support" in settings
please advise 🙏
squidkent - 回复
添加评论
浏览统计数据:
过去 24 小时: 104
过去 7 天: 656
过去 30 天: 2,561
总计 176,818
