跳转到主内容
How to Calibrate a Kobo eReader Display
  1. How to Calibrate a Kobo eReader Display, Check your VCOM number: 步骤 1 中的图像 1,3 How to Calibrate a Kobo eReader Display, Check your VCOM number: 步骤 1 中的图像 2,3 How to Calibrate a Kobo eReader Display, Check your VCOM number: 步骤 1 中的图像 3,3
    • Check the display cable for the three digit VCOM number.
    • For example: -2.81
    • If your screen doesn't have a printed VCOM number, scan the QR code with a dedicated QR scanner app to generate the number. Your smartphone's built-in camera app might not work.
    • The VCOM number registered on your eReader will be this three digit number multiplied by 1000.
    • For example: -2.81 x 1000 = -2810
  2. How to Calibrate a Kobo eReader Display, Navigate to Device Information: 步骤 2 中的图像 1,3 How to Calibrate a Kobo eReader Display, Navigate to Device Information: 步骤 2 中的图像 2,3 How to Calibrate a Kobo eReader Display, Navigate to Device Information: 步骤 2 中的图像 3,3
    • From the home screen, select More at the bottom right corner.
    • Select Settings.
    • Select Device information.
  3. How to Calibrate a Kobo eReader Display, Locate the stored VCOM number: 步骤 3 中的图像 1,2 How to Calibrate a Kobo eReader Display, Locate the stored VCOM number: 步骤 3 中的图像 2,2
    • Find the row titled Firmware information and select View.
    • The VCOM number will be listed on the popup. Compare it to the VCOM number for your screen.
    • If your VCOM numbers match, your screen is already calibrated—you're done! If the numbers don't match, follow the next three steps to change the VCOM number.
  4. How to Calibrate a Kobo eReader Display, Connect your device to a computer: 步骤 4 中的图像 1,3 How to Calibrate a Kobo eReader Display, Connect your device to a computer: 步骤 4 中的图像 2,3 How to Calibrate a Kobo eReader Display, Connect your device to a computer: 步骤 4 中的图像 3,3
    • Plug your eReader into a computer.
    • You'll be prompted on the eReader that a computer is detected. Select Connect.
    • While the eReader is connected, you can't use it.
    • If you're having trouble connecting to your computer, click here for troubleshooting information.
  5. How to Calibrate a Kobo eReader Display, Change the VCOM number: 步骤 5 中的图像 1,3 How to Calibrate a Kobo eReader Display, Change the VCOM number: 步骤 5 中的图像 2,3 How to Calibrate a Kobo eReader Display, Change the VCOM number: 步骤 5 中的图像 3,3
    • On your computer, use a text editor to create a .txt file named vcom with only the desired VCOM number (including the negative symbol and the x1000 multiplication).
    • For example, if the VCOM number on the replacement screen is -2.89, the file should say exactly -2890.
    • Find the drive called KOBOeReader and open it.
    • Move the vcom file into the drive.
  6. How to Calibrate a Kobo eReader Display: 步骤 6 中的图像 1,2 How to Calibrate a Kobo eReader Display: 步骤 6 中的图像 2,2
    • On your computer, eject the eReader.
    • Once the device successfully ejects, you'll be prompted to update the VCOM number. Select OK to update the number and restart the eReader.
    • If you don't get prompted, repeat the previous step to ensure your file was formatted and named properly.
    • Navigate back to the Firmware information page and check if your VCOM number has updated.
    • If your VCOM number is updated, you're done! If not, double check each step in this guide to confirm the procedure was done properly.
    • The updated VCOM value might not match the number you entered to the exact digit. As long as it's close, it's fine!
结论
Calibration didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
3等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
213,751 声望
创作了1,041篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,735篇指南
11指南评论
Any way of doing this on a kobo nia? I just changed my cracked screen and I don't have the vcom heading, nor do the steps work for my model.
Cheers
Mark B - 回复
I saw some posts on forums commenting that some users opened their Kobo and noticed that the VCOM indicated on the board was different from the VCOM configured in the system. My question is whether I should open my Kobo to check if my model also has a mismatched configuration. It seems that several devices are coming with them misconfigured, and here on iFixit, there is the following information: If the VCOM numbers stay mismatched for long periods of time, this may result in permanent damage to the E-ink display.
So, should I open it to check or ignore it, even though there is a possibility that my Kobo is misconfigured? Any suggestions from Kobo or iFixit regarding this?
V M - 回复
Hi, my reader's VCOM value is -1352mV and I've tried to open the back cover to check my VCOM number and found -1.36, I changed to the new value and "upload" to my reader like your procedure, but every time I reboot my device and found the value changed nothing, remains -1352mV.
I'm making sure that each step is correct. Does anyone know what's the problem?
r6b444 - 回复
The VCOM values won't match to the exact digit. In your case, they're super close together and won't pose a problem.
Carsten Frauenheim -
What variance/difference is considered acceptable? My device firmware info tab lists -1470 however the inside of the device via QR code lists -1.48.
pocketwildflwr - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 120
过去 30 天: 515
总计 12,481
