简介
The Mobius ActionCam is a small, durable video recorder often used as a helmet or dash camera. In its default factory configuration objects must be a minimum of several feet from the camera to be in reasonable focus. However, the lens can be manually adjusted to focus on objects up to approximately 4" away, allowing the device to be used for macro photography projects.
你所需要的
Use a Phillips #00 screwdriver to remove both screws on the bottom of the case.
Use a box cutter or knife to split the quality control seal on the front of the device.
2等其他人完成本指南。
3条评论
Could anyone send me an online shopping link for this item. Or is focus adjustments applicable for all Mobius ActionCam models and versions ?
There is good idea to use WebcamViewer V1.0 (You don't need to install and it's free) in order to focus adjustment "online", connecting Your Mobius CAM to PC like WebCam.
Here the link to the soft: http://www.bustatech.com/webcamviewer-a-...
