跳转到主内容
How To Repair A Wii Remote Charging Station With A Broken Capacitor
你所需要的
  1. How To Repair A Wii Remote Charging Station With A Broken Capacitor, Capacitor: 步骤 1 中的图像 1,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor, Capacitor: 步骤 1 中的图像 2,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor, Capacitor: 步骤 1 中的图像 3,3
    • Flip over the Wii Remote Charger to the bottom and remove the skid pad.
    • The skid pad itself is a very simple pad attached to the bottom of the Wii Remote Charger with very weak adhesive. It can very simply be pulled off.
    • Keep in mind that thanks to it being simple adhesive, some Wii Remote Chargers already might be missing their skid pads. The one depicted in the pictures is a replacement, so other skid pads may look different, but can be just as easily removed.
  2. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 2 中的图像 1,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 2 中的图像 2,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 2 中的图像 3,3
    • Remove the six 3mm screws on the bottom of the Wii Remote Charger with a Phillips #0 screwdriver.
    • Pull the bottom cover off to expose the internal components.
  3. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 3 中的图像 1,2 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 3 中的图像 2,2
    • Remove the three 3mm screws on the PCB (printed circuit board) with a Phillips #0 screwdriver.
    • Be careful not to miss the third screw as it's partially hidden under the cables and harder to access.
    • Lift the motherboard out of the case.
  4. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 4 中的图像 1,2 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 4 中的图像 2,2
    • To start with, find the capacitor on the top of the circuit board. Carefully flip it over and find where the capacitor attaches to the circuit board.
    • Not only is this where we'll be testing our capacitor, but it's also where we're going to be soldering.
  5. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 5 中的图像 1,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 5 中的图像 2,3 How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 5 中的图像 3,3
    • Now that we've located the capacitor on the circuit board, we'll be using two different tests on an ohmmeter to see if the capacitor works or not:
    • The first test isn't necessary, but can be used as a quick way to indicate function. If the capacitor works the meter will indicate full continuity by beeping. If it fails the test it won't beep, showing an open circuit and we need to move on to the next test. To start the test use any ohms meter and turn the dial to what's depicted in the picture.
    • The second test is a verification of the capacitor. The measures the capacitance of Farads. If the test is successful it'll indicate 1000 UF. A different number will indicate that the test is a failure and the capacitor needs to be replaced. To start the test use any ohmmeter and turn the dial to what's depicted in the picture.
  6. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 6 中的图像 1,1
    • We'll be using the soldering iron in the same locations as where the capacitance tested badly.
    • Use the soldering iron to remove the solder keeping the capacitor in place, being careful to ensure you're removing the solder under the capacitor.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices.
  7. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 7 中的图像 1,1
    • Use a pair of needle nose pliers to very carefully and slowly remove the broken capacitor.
    • After the capacitor has been removed, replace with the new capacitor.
  8. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 8 中的图像 1,1
    • Using a solder wick, resolder the new capacitor into place.
  9. How To Repair A Wii Remote Charging Station With A Broken Capacitor: 步骤 9 中的图像 1,1
    • After the new capacitor has been soldered into place, follow these steps in reverse in order to reassemble your Wii Remote Charger.
结论
Congratulations on fixing your Wii Remote Charger.
Trinity Hill
于04/29/20注册
169 声望
撰写一个指南
团队
UW Tacoma, Team S1-G20, Cardinal Spring 2020 UW Tacoma, Team S1-G20, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G20
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 707
