跳转到主内容
How To Clean Nikon Coolpix S30 Lens
你所需要的
  1. How To Clean Nikon Coolpix S30 Lens, Batteries: 步骤 1 中的图像 1,2 How To Clean Nikon Coolpix S30 Lens, Batteries: 步骤 1 中的图像 2,2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. How To Clean Nikon Coolpix S30 Lens: 步骤 2 中的图像 1,2 How To Clean Nikon Coolpix S30 Lens: 步骤 2 中的图像 2,2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. How To Clean Nikon Coolpix S30 Lens: 步骤 3 中的图像 1,1
    • Remove the batteries by gently tipping the camera.
  4. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: 步骤 4 中的图像 1,1
    • Remove the four screws the hold the back of the case to the rest of the camera.
  5. How To Clean Nikon Coolpix S30 Lens: 步骤 5 中的图像 1,1
    • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
    • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
  6. How To Clean Nikon Coolpix S30 Lens: 步骤 6 中的图像 1,1
    • Remove back case from the rest of the camera carefully.
  7. How To Clean Nikon Coolpix S30 Lens: 步骤 7 中的图像 1,1
    • Remove the three screws the secure the motherboard to the front case.
  8. How To Clean Nikon Coolpix S30 Lens: 步骤 8 中的图像 1,2 How To Clean Nikon Coolpix S30 Lens: 步骤 8 中的图像 2,2
    • Remove the motherboard from the front case.
    • Leave the red and black wire attached but lay the piece in front of the case.
  9. How To Clean Nikon Coolpix S30 Lens: 步骤 9 中的图像 1,2 How To Clean Nikon Coolpix S30 Lens: 步骤 9 中的图像 2,2
    • Wipe the lens and the clear plastic on the front case to remove debris.
结论
另外一个人完成了本指南。
Courtney Weida
于01/21/15注册
167 声望
撰写一个指南
团队
Penn State, Team 2-4, Kaschak Winter 2015 Penn State, Team 2-4, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S2G4
4 名成员
创作了5篇指南
一条评论
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 1,793
