简介
Is your headlight not functioning and you’ve tried everything else on the troubleshooting page with no luck? If so, you may want to try replacing the light and this guide will assist you in that goal. All you will need is a Hex 4 bit and a soldering iron with solder to complete this replacement.
配件
没有特定配件。
Face the front of the scooter towards you.
Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
即将完成!
To reassemble your device, follow these instructions in reverse order with the new LED.
结论
