跳转到主内容
Hover-1 Eagle Back Wheel Replacement
你所需要的
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: 步骤 1 中的图像 1,1
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: 步骤 3 中的图像 1,3 Hover-1 Eagle Back Wheel Replacement: 步骤 3 中的图像 2,3 Hover-1 Eagle Back Wheel Replacement: 步骤 3 中的图像 3,3
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: 步骤 4 中的图像 1,1
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: 步骤 5 中的图像 1,3 Hover-1 Eagle Back Wheel Replacement: 步骤 5 中的图像 2,3 Hover-1 Eagle Back Wheel Replacement: 步骤 5 中的图像 3,3
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: 步骤 6 中的图像 1,2 Hover-1 Eagle Back Wheel Replacement: 步骤 6 中的图像 2,2
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
结论
To reassemble your device, repeat Steps 1-4 in reverse order.
4等其他人完成本指南。
Andrew Gaskell
于01/23/20注册
1,008 声望
创作了5篇指南
团队
Cal Poly, Team S1-G2, White Winter 2020 Cal Poly, Team S1-G2, White Winter 2020 的会员
CPSU-WHITE-W20S1G2
4 名成员
创作了6篇指南
一条评论
Where do you buy the wheels
Thanks
antonio flores - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 45
总计 2,393
