跳转到主内容
Hover-1 Coast Controller Battery Replacement
你所需要的
  1. Hover-1 Coast Controller Battery Replacement, Controller Battery: 步骤 1 中的图像 1,3 Hover-1 Coast Controller Battery Replacement, Controller Battery: 步骤 1 中的图像 2,3 Hover-1 Coast Controller Battery Replacement, Controller Battery: 步骤 1 中的图像 3,3
    • Identify the three screws and using a Phillips #1 screwdriver loosen the the screws.
    • Remove the three screws.
  2. Hover-1 Coast Controller Battery Replacement: 步骤 2 中的图像 1,3 Hover-1 Coast Controller Battery Replacement: 步骤 2 中的图像 2,3 Hover-1 Coast Controller Battery Replacement: 步骤 2 中的图像 3,3
    • Pull the backside of the controller off.
    • The inside of the controller should look like this.
    • The marked area is the battery.
  3. Hover-1 Coast Controller Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the black foam piece covering the battery.
  4. Hover-1 Coast Controller Battery Replacement: 步骤 4 中的图像 1,2 Hover-1 Coast Controller Battery Replacement: 步骤 4 中的图像 2,2
    • Desolder the battery connections from the motherboard.
  5. Hover-1 Coast Controller Battery Replacement: 步骤 5 中的图像 1,2 Hover-1 Coast Controller Battery Replacement: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, pry the battery off the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 397
