跳转到主内容
Hover-1 Charger LED Headlight Replacement
你所需要的
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 步骤 1 中的图像 1,2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: 步骤 2 中的图像 1,1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger LED Headlight Replacement: 步骤 3 中的图像 2,2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: 步骤 4 中的图像 1,1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: 步骤 5 中的图像 1,2 Hover-1 Charger LED Headlight Replacement: 步骤 5 中的图像 2,2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: 步骤 6 中的图像 1,2 Hover-1 Charger LED Headlight Replacement, LED Headlight: 步骤 6 中的图像 2,2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: 步骤 7 中的图像 1,2 Hover-1 Charger LED Headlight Replacement: 步骤 7 中的图像 2,2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: 步骤 8 中的图像 1,1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
结论
Benji Forest
于10/10/19注册
266 声望
创作了2篇指南
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 201
