跳转到主内容
Hover-1 Charger Gyroscope Sensor Board Replacement
你所需要的
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 步骤 1 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 2 中的图像 1,1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 3 中的图像 2,2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 4 中的图像 1,1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 5 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 5 中的图像 2,2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 1,3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 2,3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: 步骤 6 中的图像 3,3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 7 中的图像 1,2 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 7 中的图像 2,2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 1,3 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 2,3 Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 8 中的图像 3,3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: 步骤 9 中的图像 1,1
    • Remove the gyroscope sensor board.
结论
另外一个人完成了本指南。
Melanie Hardell
于10/10/19注册
517 声望
创作了2篇指南
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
4指南评论
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - 回复
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - 回复
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - 回复
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 55
总计 5,749
