跳转到主内容
Hover-1 Charger Bluetooth Speaker Replacement
你所需要的
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 步骤 1 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: 步骤 1 中的图像 2,2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 2 中的图像 1,1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 3 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement: 步骤 3 中的图像 2,2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 4 中的图像 1,1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 5 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: 步骤 6 中的图像 1,1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 7 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement: 步骤 7 中的图像 2,2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 8 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 9 中的图像 1,2 Hover-1 Charger Bluetooth Speaker Replacement: 步骤 9 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: 步骤 10 中的图像 1,1
    • Remove the speaker and circuit board from the outer shell.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 31
总计 1,353
