跳转到主内容
Holmes HEH8031 Fan Replacement
你所需要的
  1. Holmes HEH8031 Fan Replacement, Housing: 步骤 1 中的图像 1,1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Fan Replacement: 步骤 3 中的图像 1,2 Holmes HEH8031 Fan Replacement: 步骤 3 中的图像 2,2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Fan Replacement, Circuit Board Removal: 步骤 4 中的图像 1,1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Fan Replacement, Circuit Board: 步骤 5 中的图像 1,3 Holmes HEH8031 Fan Replacement, Circuit Board: 步骤 5 中的图像 2,3 Holmes HEH8031 Fan Replacement, Circuit Board: 步骤 5 中的图像 3,3
    • Desolder the BLACK wires from the "AC-L" point and "T/S" point.
    • Learn how to solder and desolder connections here!
    • Desolder the WHITE wire from the "AC-N" point.
    • Desolder the RED wire from the "FAN-RED".
    • Desolder the GREY wire from the "24V" point.
    • Desolder the BROWN wires from "HEAT1," and "HEAT2" points.
    • Be sure to use desoldering wick when you remove the wire connections.
  6. Holmes HEH8031 Fan Replacement: 步骤 6 中的图像 1,2 Holmes HEH8031 Fan Replacement: 步骤 6 中的图像 2,2
    • Desolder the WHITE connector (attached to the GRAY wire coming of the thermostat) from the "NTC101" point.
  7. Holmes HEH8031 Fan Replacement, Fan: 步骤 7 中的图像 1,1
    • Remove two Phillips #2 12mm screws from housing
  8. Holmes HEH8031 Fan Replacement: 步骤 8 中的图像 1,1
    • Remove zip tie from wire with pliers
  9. Holmes HEH8031 Fan Replacement: 步骤 9 中的图像 1,1
    • Separate fan assembly from heating coil
结论
另外一个人完成了本指南。
Torben Eid
于10/13/16注册
1 声望
撰写一个指南
团队
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G1
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 330
