跳转到主内容
Hisense Sero 8 Speaker Replacement
你所需要的
  1. Hisense Sero 8 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Hisense Sero 8 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Hisense Sero 8 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool to pry open a corner of the device. Continue using the tool down the side of the device to open it completely.
  2. Hisense Sero 8 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the black tape located to the left of the device.
  3. Hisense Sero 8 Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips head #00 screwdriver to remove the two 4.43mm screws on the bottom that keep the speakers in place.
  4. Hisense Sero 8 Speaker Replacement: 步骤 4 中的图像 1,2 Hisense Sero 8 Speaker Replacement: 步骤 4 中的图像 2,2
    • Unsolder the red and black wires connecting the speaker to the motherboard. Take a look at this guide to learn how to solder and unsolder connections.
  5. Hisense Sero 8 Speaker Replacement: 步骤 5 中的图像 1,2 Hisense Sero 8 Speaker Replacement: 步骤 5 中的图像 2,2
    • Use the spudger tool to remove the speaker panel carefully.
结论
另外一个人完成了本指南。
Katharina
于02/23/15注册
506 声望
创作了2篇指南
团队
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 573
