跳转到主内容
Hisense Sero 8 Motherboard Replacement
你所需要的
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Hisense Sero 8 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Hisense Sero 8 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: 步骤 2 中的图像 1,2 Hisense Sero 8 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: 步骤 5 中的图像 1,3 Hisense Sero 8 Motherboard Replacement: 步骤 5 中的图像 2,3 Hisense Sero 8 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
结论
Katharina
于02/23/15注册
506 声望
创作了2篇指南
团队
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 的会员
USFT-LEAHY-W15S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,359
