跳转到主内容
Hipstreet Titan Plus Battery Replacement
你所需要的
  1. Hipstreet Titan Plus Battery Replacement, Battery: 步骤 1 中的图像 1,2 Hipstreet Titan Plus Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before beginning this process, make sure the device is powered off.
    • Use the plastic opening tools from iFixit to safely remove the screen from the back of the device.
    • Lift and remove screen to reveal the battery and circuit board as seen in the picture.
  2. Hipstreet Titan Plus Battery Replacement: 步骤 2 中的图像 1,1
    • Preparing to remove the speaker.
    • Use spudger to remove the speaker from the back casing of the device.
    • Note: Handle with care
  3. Hipstreet Titan Plus Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the black strips as shown in the picture from the wires using the tweezers.
    • Be careful of handling, if not done correctly you will need to replace.
  4. Hipstreet Titan Plus Battery Replacement: 步骤 4 中的图像 1,2 Hipstreet Titan Plus Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully use the spatula and spudger from iFixit to remove the battery from the device.
    • Note: The different color wires needs to be reconnected onto the proper terminals on the circuit board
    • Note: here is a how to solder and desolder connections guide to properly do step 5. 如何焊接和拆焊
    • Dispose of the old battery properly.
  5. Hipstreet Titan Plus Battery Replacement: 步骤 5 中的图像 1,2 Hipstreet Titan Plus Battery Replacement: 步骤 5 中的图像 2,2
    • Heat the soldering iron to operating temperature.
    • Use caution as to not harm yourself when using the hot soldering iron.
    • Locate the black and red wires on the top of the circuit board.
    • Note: Remember the placement of the red and black wires on the circuit board.
    • Using the soldering iron, apply heat to the shiny solder point on the circuit board (Circled on the picture).
    • Note: Be sure not to break the wire when pulling the wires off. Let the solder melt in order to remove the wire.
    • Be sure to perform this task for both the black and red wires.
    • Note: If the iron is not hot enough, you might encounter unsuccessful removal of the wires. In order to correct this, let the soldering iron heat up completely to try this step again.
结论
另外一个人完成了本指南。
Justin Machnik
于10/30/15注册
194 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-1, Miles Fall 2015 UMass Dartmouth, Team 1-1, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 921
