简介
Some possible symptoms which could show that your battery needs to be replaced:
- Battery percentage remains low, even after charging.
- The tablet dies when it still has a lot of battery life.
- The tablet becomes hot after using for a short period of time.
If you experience these symptoms, you might need to get a new battery. This battery replacement guide will walk you through the steps on how to remove necessary components in order to get to the battery. Replacing the battery is a moderate five step process using the necessary tools (refer to tools list).
你所需要的
Use the plastic opening tools from iFixit to safely remove the screen from the back of the device.
Lift and remove screen to reveal the battery and circuit board as seen in the picture.
另外一个人完成了本指南。
