跳转到主内容
加入维修社区 - 创建账户
Heating Element Contacts
你所需要的
  1. Heating Element Contacts, Heating Element Contacts: 步骤 1 中的图像 1,3 Heating Element Contacts, Heating Element Contacts: 步骤 1 中的图像 2,3 Heating Element Contacts, Heating Element Contacts: 步骤 1 中的图像 3,3
    • Before you begin, be sure to unplug your coffee maker.
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the T10 Torx screwdriver to remove all four 17 mm-long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
    询问修复机器人
    添加评论
  2. Heating Element Contacts: 步骤 2 中的图像 1,2 Heating Element Contacts: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixHub Smart Soldering Iron
    $79.95
    • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G1
4 名成员
创作了15篇指南
1指南评论
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 75
总计 4,008
