跳转到主内容
Health o Meter HDR743 Circuit Board Replacement
你所需要的
  1. Health o Meter HDR743 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Use a soldering iron to remove each connection between a component and the circuit board.
    • For more information on how to solder and desolder connections, please visit this guide.
  2. Health o Meter HDR743 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Carefully add solder to each area where a connection will be made on the new board. This will make it easier to actually create connections.
  3. Health o Meter HDR743 Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Solder all of the components back onto the new board being very careful to not let any of the connections touch, which would cause more errors.
  4. Health o Meter HDR743 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Make sure that the scale is working correctly with the new circuit board. If there are issues, check each connection and if they persist it may be another component depending on the issue.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 214
