跳转到主内容
加入维修社区 - 创建账户
Head Strap Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Head Strap Removal, Remove the front side foam pads: 步骤 1 中的图像 1,3 Head Strap Removal, Remove the front side foam pads: 步骤 1 中的图像 2,3 Head Strap Removal, Remove the front side foam pads: 步骤 1 中的图像 3,3
    • Peel off both front side foam pads to uncover the speaker wires.
  2. Head Strap Removal, Remove the two rubber spacers: 步骤 2 中的图像 1,3 Head Strap Removal, Remove the two rubber spacers: 步骤 2 中的图像 2,3 Head Strap Removal, Remove the two rubber spacers: 步骤 2 中的图像 3,3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  3. Head Strap Removal, Disconnect the speaker wires: 步骤 3 中的图像 1,3 Head Strap Removal, Disconnect the speaker wires: 步骤 3 中的图像 2,3 Head Strap Removal, Disconnect the speaker wires: 步骤 3 中的图像 3,3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  4. Head Strap Removal, Remove the head strap: 步骤 4 中的图像 1,2 Head Strap Removal, Remove the head strap: 步骤 4 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  5. Head Strap Removal: 步骤 5 中的图像 1,1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  6. Head Strap Removal: 步骤 6 中的图像 1,3 Head Strap Removal: 步骤 6 中的图像 2,3 Head Strap Removal: 步骤 6 中的图像 3,3
    • Thread the headphone speaker wires out through both ends of the head strap.
结论
Sam Omiotek
于02/25/19注册
95,654 声望
创作了290篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 54
