本指南有最近更改,您可查看未经巡查的最新版本。
简介
The button board can be easily pulled off without damaging the device. The only tool you need is a #00 Philips screwdriver.
你所需要的
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
即将完成!
结论
