当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Do not pull on the flip cover in an attempt to remove it from the PDA.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the gray back plate from the PDA.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
Gently remove the white frame from the back of the PDA.
Pull off front cover gently.
Remove buttons by hand, they should come off easily.
取消:我没有完成这个指南。
与3其他贡献者
于01/23/11注册
331 声望
创作了3篇指南
徽章: 7
+ 4更多徽章
CPSU-MANESS-W11S11G28
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 14
总计 768
