跳转到主内容
Hand-Held Blender Motor Replacement
你所需要的
  1. Hand-Held Blender Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: 步骤 2 中的图像 1,1
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: 步骤 3 中的图像 1,1
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: 步骤 4 中的图像 1,1
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: 步骤 5 中的图像 1,1
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: 步骤 6 中的图像 1,1
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: 步骤 7 中的图像 1,1
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 74
总计 3,363
