跳转到主内容
HTC Vive XR Elite Rear Padding Replacement
你所需要的
  1. HTC Vive XR Elite Rear Padding Replacement, Prepare your Vive XR Elite for disassembly: 步骤 1 中的图像 1,1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
  3. HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 步骤 3 中的图像 1,3 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 步骤 3 中的图像 2,3 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 步骤 3 中的图像 3,3
    • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
  4. HTC Vive XR Elite Rear Padding Replacement: 步骤 4 中的图像 1,2 HTC Vive XR Elite Rear Padding Replacement: 步骤 4 中的图像 2,2
    • Flip the battery cradle over.
    • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
  5. HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 步骤 5 中的图像 1,3 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 步骤 5 中的图像 2,3 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 步骤 5 中的图像 3,3
    • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
  6. HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: 步骤 6 中的图像 1,2 HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: 步骤 6 中的图像 2,2
    • Pull apart the two halves of the battery cradle to completely separate them.
    • Use a T5 Torx screwdriver to remove the four 4.9 mm-long screws securing the rear padding.
  7. HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 步骤 8 中的图像 1,3 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 步骤 8 中的图像 2,3 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 步骤 8 中的图像 3,3
    • Pivot one of the rear padding clips toward the center of the frame.
    • Lift the rear padding up to unclip it.
  8. HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 步骤 9 中的图像 1,3 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 步骤 9 中的图像 2,3 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 步骤 9 中的图像 3,3
    • The rear padding is not symmetrical. Note its orientation before continuing.
    • Unclip the remaining rear padding clip.
    • Remove the rear padding.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Chayton Ritter
于08/21/20注册
15,959 声望
创作了96篇指南
团队
Guide Team Guide Team 的会员
Staff
6 名成员
创作了5,999篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 33
