跳转到主内容
HTC Vive Pro Headphone Replacement
你所需要的
  1. HTC Vive Pro Headphone Replacement, Remove the head strap padding: 步骤 1 中的图像 1,3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: 步骤 1 中的图像 2,3 HTC Vive Pro Headphone Replacement, Remove the head strap padding: 步骤 1 中的图像 3,3
    • Peel off the thin piece of padding covering the headphone screw for each headphone you are replacing.
  2. HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): 步骤 2 中的图像 1,2 HTC Vive Pro Headphone Replacement, Unscrew the headphone(s): 步骤 2 中的图像 2,2
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing each headphone you are replacing.
  3. HTC Vive Pro Headphone Replacement, Remove the headphone(s): 步骤 3 中的图像 1,3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): 步骤 3 中的图像 2,3 HTC Vive Pro Headphone Replacement, Remove the headphone(s): 步骤 3 中的图像 3,3
    • Remove the headphone(s).
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
另外一个人完成了本指南。
Sam Omiotek
于02/25/19注册
76,055 声望
创作了288篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 65
总计 1,455
