跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的HTC Rezound,请使用我们的维修手册
  1. HTC Rezound Teardown, HTC Rezound Teardown: 步骤 1 中的图像 1,3 HTC Rezound Teardown, HTC Rezound Teardown: 步骤 1 中的图像 2,3 HTC Rezound Teardown, HTC Rezound Teardown: 步骤 1 中的图像 3,3
    • Remove rear cover using little notch located at bottom of phone
  2. HTC Rezound Teardown: 步骤 2 中的图像 1,1
    • Remove 1620 mAh battery
    • Remove SD card
    • Phone comes with 16 GB SD card
  3. HTC Rezound Teardown: 步骤 3 中的图像 1,2 HTC Rezound Teardown: 步骤 3 中的图像 2,2
    • Remove (6) Torx T7 screws
    • You may have to remove VOID sticker from one of the screws
  4. HTC Rezound Teardown: 步骤 4 中的图像 1,3 HTC Rezound Teardown: 步骤 4 中的图像 2,3 HTC Rezound Teardown: 步骤 4 中的图像 3,3
    • Use opener tool to carefully pry cover off
    • Volume and power buttons are located in cover so be careful not to lose them
    • Speaker is located inside back cover
    • Main Camera
    • Headphone jack
    • Vibration motor
  5. HTC Rezound Teardown: 步骤 5 中的图像 1,3 HTC Rezound Teardown: 步骤 5 中的图像 2,3 HTC Rezound Teardown: 步骤 5 中的图像 3,3
    • Carefully unplug board
    • Carefully remove camera cover, slowly peeling off tape to reuse
    • Remove and unplug vibration motor
  6. HTC Rezound Teardown: 步骤 6 中的图像 1,3 HTC Rezound Teardown: 步骤 6 中的图像 2,3 HTC Rezound Teardown: 步骤 6 中的图像 3,3
    • Remove (2) Phillips heads screws (one is shown, the other is on the left lower side)
    • Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly.
    • Main camera connection & front camera
  7. HTC Rezound Teardown: 步骤 7 中的图像 1,2 HTC Rezound Teardown: 步骤 7 中的图像 2,2
    • Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
  8. HTC Rezound Teardown: 步骤 8 中的图像 1,1
    • For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
Codyhatch24
于12/26/13注册
201 声望
撰写一个指南
团队
Android Alliance Android Alliance 的会员
Community
87 名成员
创作了699篇指南
2条评论
If there's anything I can add to help make this more clear cut and easy to follow let me know as this is my first attempt at a guide.
Codyhatch24 - 回复
My rezound glass is cracked . It still operates fine but I would like to replace the glass. I ordered a glass from Amazon but it has a connection tail that I don't understand how to install?
Lee Ferguson -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 3,983
