跳转到主内容
HTC One Speaker Replacement
你所需要的
  1. HTC One Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 HTC One Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 HTC One Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: 步骤 2 中的图像 1,1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: 步骤 6 中的图像 1,2 HTC One Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: 步骤 7 中的图像 1,2 HTC One Speaker Replacement: 步骤 7 中的图像 2,2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: 步骤 8 中的图像 1,3 HTC One Speaker Replacement: 步骤 8 中的图像 2,3 HTC One Speaker Replacement: 步骤 8 中的图像 3,3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: 步骤 9 中的图像 1,2 HTC One Speaker Replacement: 步骤 9 中的图像 2,2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
结论
16等其他人完成本指南。
Alex
于09/23/14注册
664 声望
撰写一个指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G1
4 名成员
创作了7篇指南
2条评论
Ok I will good
Raguraman - 回复
Where to buy speaker???
bharatdshmkh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 19,441
