跳转到主内容
HTC One Remix Motherboard Replacement
你所需要的
  1. HTC One Remix Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. HTC One Remix Motherboard Replacement: 步骤 2 中的图像 1,1
    • Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
    • iOpener 指南
  3. HTC One Remix Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • The top is glued on so it may be difficult to get off.
  4. HTC One Remix Motherboard Replacement: 步骤 4 中的图像 1,1
    • Take out the small 3 mm screw that is on the top left side using a T5 bit.
  5. HTC One Remix Motherboard Replacement: 步骤 5 中的图像 1,2 HTC One Remix Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
    • Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • The plastic spudger may not work. If this is the case, you may have to resort to using the metal prying tool. Please use with caution.
  6. HTC One Remix Motherboard Replacement: 步骤 6 中的图像 1,2 HTC One Remix Motherboard Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • With tweezers, remove the small pieces of yellow tape that hold the phone in place.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper place.
    • Please note that the second photo is upside-down.
  7. HTC One Remix Motherboard Replacement: 步骤 7 中的图像 1,3 HTC One Remix Motherboard Replacement: 步骤 7 中的图像 2,3 HTC One Remix Motherboard Replacement: 步骤 7 中的图像 3,3
    • With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
    • Use tweezers to carefully detach the eight ribbon cables from the connectors.
  8. HTC One Remix Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the two 1 mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
  9. HTC One Remix Motherboard Replacement: 步骤 9 中的图像 1,2 HTC One Remix Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull the black and red wire from the motherboard on the bottom left.
  10. HTC One Remix Motherboard Replacement: 步骤 10 中的图像 1,1
    • Take out the four 3 mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic spudger.
    • Watch the ribbon connectors when removing the motherboard as they may get in the way.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 142
