跳转到主内容
加入维修社区 - 创建账户
HTC One Remix Battery Replacement
你所需要的
  1. HTC One Remix Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. HTC One Remix Battery Replacement: 步骤 2 中的图像 1,1
    • Place the warm iOpener on top of the phone for three minutes.
    • iOpener 指南
  3. HTC One Remix Battery Replacement: 步骤 3 中的图像 1,1
    • Once the top of the phone is warm, use a plastic spudger to pry up the left corner and pull it off.
    • The top is glued on so it may be difficult to pull off.
  4. HTC One Remix Battery Replacement: 步骤 4 中的图像 1,1
    • Take out the single 3mm screw that is on the top left side using a Torx 4 screwdriver.
  5. HTC One Remix Battery Replacement: 步骤 5 中的图像 1,2 HTC One Remix Battery Replacement: 步骤 5 中的图像 2,2
    • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift the back cover with force. Continue to do this all around the phone.
    • Be careful not to break the wiring that is connected from the inside of the phone to the back of the phone.
  6. HTC One Remix Battery Replacement: 步骤 6 中的图像 1,2 HTC One Remix Battery Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • With tweezers, remove the small pieces of yellow tape that cover the ZIF connectors.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper plate.
  7. HTC One Remix Battery Replacement: 步骤 7 中的图像 1,3 HTC One Remix Battery Replacement: 步骤 7 中的图像 2,3 HTC One Remix Battery Replacement: 步骤 7 中的图像 3,3
    • With the plastic spudger, disconnect the eight ZIF connectors.
    • Use tweezers to carefully detach the eight ribbon cables from the ZIF connectors.
  8. HTC One Remix Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the two 1mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
  9. HTC One Remix Battery Replacement: 步骤 9 中的图像 1,3 HTC One Remix Battery Replacement: 步骤 9 中的图像 2,3 HTC One Remix Battery Replacement: 步骤 9 中的图像 3,3
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull back the black and red wire on the motherboard on the bottom left.
  10. HTC One Remix Battery Replacement: 步骤 10 中的图像 1,1
    • Take out the four 3mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic spudger.
    • Make sure the ribbon cables are out of the way when removing the motherboard.
  11. HTC One Remix Battery Replacement: 步骤 11 中的图像 1,1
    • Pull back the ZIF and ribbon connectors and place the plastic opening tool into the indentation between the battery and the frame of the phone. Continue to do this around each side of the battery by gently prying.
  12. HTC One Remix Battery Replacement: 步骤 12 中的图像 1,1
    • Gently pull the battery from the HTC One Remix.
    • This may be somewhat difficult due to the adhesive keeping the battery in place. Carefully pull and watch the orange tab at the bottom right of the battery. It may get stuck.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 737
