当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Use a metal spudger to pry up the left edge of the upper grey front plate.
Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Use the plastic pry tool to pry around the edge of the phone.
Pry carefully around the card slots.
Slowly pull up from the right side of the screen like opening a book.
The plastic piece for the power button may fall out. Set it aside for reassembly.
Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
On the left side, pop the white tab up to the left. On the right, pop up to the right.
Carefully pull out the ribbon cables.
Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
Pop up the battery connector using the flat end of the spudger.
Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
Once the screws are removed, carefully pull the copper plated motherboard out.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
