当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a metal spudger to pry up the left edge of the upper grey front plate.
Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Use the plastic pry tool to pry around the edge of the phone.
Pry carefully around the card slots.
Slowly pull up from the right side of the screen like opening a book.
The plastic piece for the power button may fall out. Set it aside for reassembly.
Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
