跳转到主内容
加入维修社区 - 创建账户
HTC One Mini 2 Back Plate Replacement
你所需要的
  1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: 步骤 1 中的图像 1,3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: 步骤 1 中的图像 2,3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: 步骤 1 中的图像 3,3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Back Plate Replacement: 步骤 2 中的图像 1,1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Back Plate Replacement, Front Plate: 步骤 3 中的图像 1,3 HTC One Mini 2 Back Plate Replacement, Front Plate: 步骤 3 中的图像 2,3 HTC One Mini 2 Back Plate Replacement, Front Plate: 步骤 3 中的图像 3,3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Back Plate Replacement: 步骤 4 中的图像 1,2 HTC One Mini 2 Back Plate Replacement: 步骤 4 中的图像 2,2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Back Plate Replacement: 步骤 5 中的图像 1,2 HTC One Mini 2 Back Plate Replacement: 步骤 5 中的图像 2,2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
结论
5等其他人完成本指南。
Caleb Kelsay
于10/14/14注册
590 声望
撰写一个指南
团队
Cal Poly, Team 4-48, Amido Fall 2014 Cal Poly, Team 4-48, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G48
5 名成员
创作了17篇指南
1指南评论
what is the black ribbon antenna on the front
deancvijic90 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 38
总计 10,584
