跳转到主内容
加入维修社区 - 创建账户
HTC One M8 Headphone Jack/Micro USB Board Replacement
你所需要的
  1. HTC One M8 Headphone Jack/Micro USB Board Replacement, SIM Card: 步骤 1 中的图像 1,2 HTC One M8 Headphone Jack/Micro USB Board Replacement, SIM Card: 步骤 1 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
    添加评论
  2. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    添加评论
  3. HTC One M8 Headphone Jack/Micro USB Board Replacement, MicroSD Card: 步骤 3 中的图像 1,2 HTC One M8 Headphone Jack/Micro USB Board Replacement, MicroSD Card: 步骤 3 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
    添加评论
  4. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 4 中的图像 1,1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
    添加评论
  5. HTC One M8 Headphone Jack/Micro USB Board Replacement, Rear Case: 步骤 5 中的图像 1,2 HTC One M8 Headphone Jack/Micro USB Board Replacement, Rear Case: 步骤 5 中的图像 2,2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
    添加评论
  6. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 6 中的图像 1,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 6 中的图像 2,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 6 中的图像 3,3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
    添加评论
  7. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 7 中的图像 1,2 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
    添加评论
  8. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 8 中的图像 1,1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
    添加评论
  9. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 9 中的图像 1,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 9 中的图像 2,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 9 中的图像 3,3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
    添加评论
  10. HTC One M8 Headphone Jack/Micro USB Board Replacement, Headphone Jack/Micro USB Board: 步骤 10 中的图像 1,2 HTC One M8 Headphone Jack/Micro USB Board Replacement, Headphone Jack/Micro USB Board: 步骤 10 中的图像 2,2
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
    询问修复机器人
    添加评论
  11. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 11 中的图像 1,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 11 中的图像 2,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
    添加评论
  12. HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 12 中的图像 1,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 12 中的图像 2,3 HTC One M8 Headphone Jack/Micro USB Board Replacement: 步骤 12 中的图像 3,3
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
    添加评论
结论
取消:我没有完成这个指南。
71等其他人完成本指南。
团队
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G9
4 名成员
创作了24篇指南
23指南评论
Worked for me - though looks like I will need to reopen as there is a problem with the wifi antenna & bluetooth connection is weak
Timothy Cockle - 回复 分享
where can i buy
Sheraz Hussain - 回复 分享
i dont have one from sprint or horizon.. Which one do i buy?
Vik De Brandt - 回复 分享
Anybody want a new battery and charging port? Ok, only slightly used as the repair failed. When I got everything back together the LCD/backlight won't come on. I could charge the battery fine and you can feel the device responding to touch so the sensors in the display are working, but the screen will not light up what so ever. Now after a 3rd attempt to disassemble and reassemble searching in vane to find a lose connection there's a new problem, when I connect the battery lead to the terminals the phone vibrates. The only way to make the phone stop vibrating is to disconnect the battery. I can only assume this phone is now toast so it would be a shame to toss the 2 new parts...
spepperdine - 回复 分享
How much? I'm having issues with the charging port not connecting to the micro used well
Jeremy Hunton - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 58
总计 69,745
