跳转到主内容
加入维修社区 - 创建账户
HTC One M8 Display Assembly Replacement
你所需要的
  1. HTC One M8 Display Assembly Replacement, SIM Card: 步骤 1 中的图像 1,2 HTC One M8 Display Assembly Replacement, SIM Card: 步骤 1 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
    添加评论
  2. HTC One M8 Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    添加评论
  3. HTC One M8 Display Assembly Replacement, MicroSD Card: 步骤 3 中的图像 1,2 HTC One M8 Display Assembly Replacement, MicroSD Card: 步骤 3 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
    添加评论
  4. HTC One M8 Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
    添加评论
  5. HTC One M8 Display Assembly Replacement, Rear Case: 步骤 5 中的图像 1,2 HTC One M8 Display Assembly Replacement, Rear Case: 步骤 5 中的图像 2,2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
    添加评论
  6. HTC One M8 Display Assembly Replacement: 步骤 6 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 6 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
    添加评论
  7. HTC One M8 Display Assembly Replacement: 步骤 7 中的图像 1,2 HTC One M8 Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
    添加评论
  8. HTC One M8 Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
    添加评论
  9. HTC One M8 Display Assembly Replacement: 步骤 9 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 9 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
    添加评论
  10. HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: 步骤 10 中的图像 1,2 HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: 步骤 10 中的图像 2,2
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
    询问修复机器人
    添加评论
  11. HTC One M8 Display Assembly Replacement: 步骤 11 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 11 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
    添加评论
  12. HTC One M8 Display Assembly Replacement: 步骤 12 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 12 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 12 中的图像 3,3
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
    添加评论
  13. HTC One M8 Display Assembly Replacement, Display Assembly: 步骤 13 中的图像 1,3 HTC One M8 Display Assembly Replacement, Display Assembly: 步骤 13 中的图像 2,3 HTC One M8 Display Assembly Replacement, Display Assembly: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the tip of a spudger to disconnect the seven ZIF connectors.
    • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
    添加评论
  14. HTC One M8 Display Assembly Replacement: 步骤 14 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 14 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 14 中的图像 3,3
    • Use an iOpener to loosen the adhesive securing the display assembly to the rest of the device.
    • Use a suction cup to gently separate the display assembly from the rest of the device.
    询问修复机器人
    添加评论
  15. HTC One M8 Display Assembly Replacement: 步骤 15 中的图像 1,3 HTC One M8 Display Assembly Replacement: 步骤 15 中的图像 2,3 HTC One M8 Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Carefully guide the display assembly ribbon cable through the midframe for removal.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
70等其他人完成本指南。
团队
Cal Poly, Team 5-9, Maness Spring 2015 Cal Poly, Team 5-9, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G9
4 名成员
创作了24篇指南
10指南评论
Great guide - many thanks!
In step 13, you only need to disconnect four ZIF connectors - the top two on the left and top one on the right can be left connected.
Thanks again!
Byrn
Byrn - 回复 分享
Be careful when reassembling:
Make sure the power button is put in the right way, it may look symmetrical but it's not! When put in the wrong way it does not work. Check if the shape of the button aligns with the edge of the casing, it's pretty easy to see if you pay attention to it.
Also keep an eye on the back camera. The round black cover glass may shift when trying to click the phone in its casing.
I ended up taking it apart at least 4 times because of this :(
Also, if you want to heat things up you can also use an incandescent light bulb and put your phone over it.
Jan de Vries - 回复 分享
position of the square block on the power button is a little bit left from the center (phone facing you with screen)
AG Draaijer - 回复 分享
don't follow step 13 in fact &&^& this guide listen to byrn
DeAndre Barron - 回复 分享
very helpful, thanks
Stuart Gilks - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 91
总计 55,799
