本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove and replace the optical joystick on your Droid Incredible.
你所需要的
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Press the MicroSD card further into its slot until it clicks.
Release the MicroSD card, and it will pop out slightly.
Remove four T6 Torx screws securing the rear inner frame to the front case.
另外一个人完成了本指南。
