当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
Lift the top of the battery up and remove the battery from the rear inner frame.
Press the MicroSD card further into its slot until it clicks.
Release the MicroSD card, and it will pop out slightly.
Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
Flip the ZIF connector on the optical joystick cable.
Lift the optical joystick out of its socket.
Use a pair of tweezers to pull the optical joystick ribbon cable straight out of its socket.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
