简介
This guide will show you how to replace the back camera of your HTC Desire 826 device. If your back camera is broken or functioning poorly, this guide will lead you through the replacement steps.
This guide only shows you how to disassemble the device to locate the back camera. To fully replace, you will need a replacement back camera part. You will need to follow the steps in reverse to put the device back together.
To begin this project we recommend that you find a clean, dry, and flat surface to work on.
Note: the images presented show a before and an after picture for each individual step to help you keep track of your progress.
你所需要的
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
