跳转到主内容
HP ZBook 15 Wi-Fi Card Replacement
你所需要的
  1. HP ZBook 15 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,2 HP ZBook 15 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Wi-Fi Card Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,1
    • Lift up the two tabs connected to wires.
  4. HP ZBook 15 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 HP ZBook 15 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3mm screws from the corners of the card with a Phillips #0 screwdriver.
    • Lift the card up and slide it out to disconnect it.
结论
3等其他人完成本指南。
Grant Terris
于01/30/15注册
2,828 声望
创作了12篇指南
团队
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G43
4 名成员
创作了15篇指南
一条评论
I’m planning to upgrade my Zbook by installing a Wireless AC-capable WiFi module. I’ve found a cheap one that’s compatible according to the service manual: the Intel 7260HMW. However, it doesn’t have an HP SPS, it seems to have come from a DELL laptop.
Has anyone tried this? Will it work? I guess I’ll find out the hard way!
Hopefully, the seller will allow me to test the adapter before buying.
Luis Alejandro Araúz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 45
总计 5,538
