跳转到主内容
HP ZBook 15 Hard Drive Replacement
你所需要的
  1. HP ZBook 15 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP ZBook 15 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: 步骤 3 中的图像 1,1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  4. HP ZBook 15 Hard Drive Replacement: 步骤 4 中的图像 1,2 HP ZBook 15 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the green tab away from the metal casing and lift the drive out.
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
结论
13等其他人完成本指南。
Grant Terris
于01/30/15注册
2,834 声望
创作了12篇指南
团队
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G43
4 名成员
创作了15篇指南
3条评论
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - 回复
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - 回复
how hard disk i can buy for my zbook 15?
thanks
francesco perego - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 102
总计 29,270
