跳转到主内容
HP Z2 Mini G3 Real-Time Clock Battery Replacement
  1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: 步骤 1 中的图像 1,1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 步骤 2 中的图像 1,2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 步骤 2 中的图像 2,2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 步骤 3 中的图像 1,2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: 步骤 3 中的图像 2,2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: 步骤 4 中的图像 1,1
    • Rotate the device so the back-side is facing you and locate the RTC battery.
    • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
  5. HP Z2 Mini G3 Real-Time Clock Battery Replacement: 步骤 5 中的图像 1,1
    • Press the battery down and away to free it of the latches.
    • Use your hand to grab and lift the battery out of the socket.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 123
总计 4,061
