跳转到主内容
HP Stream 14-CB174WM Battery Replacement
你所需要的
  1. HP Stream 14-CB174WM Battery Replacement, Lower Case: 步骤 1 中的图像 1,2 HP Stream 14-CB174WM Battery Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
  2. HP Stream 14-CB174WM Battery Replacement: 步骤 2 中的图像 1,2 HP Stream 14-CB174WM Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
  3. HP Stream 14-CB174WM Battery Replacement: 步骤 3 中的图像 1,3 HP Stream 14-CB174WM Battery Replacement: 步骤 3 中的图像 2,3 HP Stream 14-CB174WM Battery Replacement: 步骤 3 中的图像 3,3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
  4. HP Stream 14-CB174WM Battery Replacement, Battery: 步骤 4 中的图像 1,3 HP Stream 14-CB174WM Battery Replacement, Battery: 步骤 4 中的图像 2,3 HP Stream 14-CB174WM Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove the following Phillips screws that secure the battery:
    • Three 2.9 mm
    • Two 6.8 mm
    • Be sure to keep different screw types separate from one another throughout the battery removal process.
  5. HP Stream 14-CB174WM Battery Replacement: 步骤 5 中的图像 1,2 HP Stream 14-CB174WM Battery Replacement: 步骤 5 中的图像 2,2
    • Use your fingers or the point of a spudger to slowly “wiggle” the battery connector directly out of its socket.
    • Do not pull on the wires.
  6. HP Stream 14-CB174WM Battery Replacement: 步骤 6 中的图像 1,2 HP Stream 14-CB174WM Battery Replacement: 步骤 6 中的图像 2,2
    • Gently unseat the battery connector wire out from under the two plastic tabs.
  7. HP Stream 14-CB174WM Battery Replacement: 步骤 7 中的图像 1,2 HP Stream 14-CB174WM Battery Replacement: 步骤 7 中的图像 2,2
    • Lift the battery up and out of the laptop.
    • The battery should lift out with very little effort. If the battery cannot easily be lifted out of the laptop chassis, check to see if you missed any screws.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 40
总计 410
