跳转到主内容
HP Stream 13-c010nr Display Replacement
你所需要的
  1. HP Stream 13-c010nr Display Replacement, HP Stream 13-c010nr Disassembly: 步骤 1 中的图像 1,1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Display Replacement: 步骤 2 中的图像 1,2 HP Stream 13-c010nr Display Replacement: 步骤 2 中的图像 2,2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Display Replacement: 步骤 3 中的图像 1,2 HP Stream 13-c010nr Display Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Display Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Display Replacement, Display: 步骤 5 中的图像 1,1
    • Remove the screw covers from the bottom corner edges of the screen.
  6. HP Stream 13-c010nr Display Replacement: 步骤 6 中的图像 1,2 HP Stream 13-c010nr Display Replacement: 步骤 6 中的图像 2,2
    • Remove the two 5mm Phillips #0 screws from the screen bezel.
  7. HP Stream 13-c010nr Display Replacement: 步骤 7 中的图像 1,2 HP Stream 13-c010nr Display Replacement: 步骤 7 中的图像 2,2
    • Wedge the plastic opening tool between the frame of the screen and the casing of the laptop.
    • Pry upwards on the plastic opening tool to separate the bezel from the display.
  8. HP Stream 13-c010nr Display Replacement: 步骤 8 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws from the screen.
  9. HP Stream 13-c010nr Display Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the screen ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF socket.
    • Remove the screen.
结论
Keegan Lapham
于02/22/18注册
759 声望
创作了6篇指南
团队
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 723
