跳转到主内容
HP Stream 13-c010nr Charging Port Replacement
你所需要的
  1. HP Stream 13-c010nr Charging Port Replacement, HP Stream 13-c010nr Disassembly: 步骤 1 中的图像 1,1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Charging Port Replacement: 步骤 2 中的图像 1,2 HP Stream 13-c010nr Charging Port Replacement: 步骤 2 中的图像 2,2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Charging Port Replacement: 步骤 3 中的图像 1,2 HP Stream 13-c010nr Charging Port Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Charging Port Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,1
    • Disconnect the charging port from the motherboard.
  6. HP Stream 13-c010nr Charging Port Replacement: 步骤 6 中的图像 1,2 HP Stream 13-c010nr Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the two 5mm Phillips screws from the charging port.
    • Remove the bracket.
    • Pull out the charging port.
结论
Keegan Lapham
于02/22/18注册
759 声望
创作了6篇指南
团队
USF Tampa, Team S1-G3, Cagle Spring 2018 USF Tampa, Team S1-G3, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 507
