本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
即将完成!
结论
另外一个人完成了本指南。
