Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
Be careful not to pull too hard on the cable connecting the power button control circuit board and the secondary control circuit board to the main circuit board
Grasp the bottom of the drive motor (Hidden behind the housing in images 1-2) and rock it away from the center of the cabal loop to release the tension in the cable.
Using your fingers, unhook the cable from drive motor.
