跳转到主内容
HP Photosmart D110a LCD Screen Replacement
你所需要的
  1. HP Photosmart D110a LCD Screen Replacement, Printer Hood Assembly: 步骤 1 中的图像 1,1
    • Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. HP Photosmart D110a LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the scanner flap gently away from the printer to release its two clips.
  3. HP Photosmart D110a LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
  4. HP Photosmart D110a LCD Screen Replacement: 步骤 4 中的图像 1,3 HP Photosmart D110a LCD Screen Replacement: 步骤 4 中的图像 2,3 HP Photosmart D110a LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Using a T-9 screwdriver, remove the three screws from the printer's top.
  5. HP Photosmart D110a LCD Screen Replacement: 步骤 5 中的图像 1,2 HP Photosmart D110a LCD Screen Replacement: 步骤 5 中的图像 2,2
    • To remove the power button panel:
    • Reach inside the printer's front opening.
    • Press the small clip behind the power button.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • Pull the panel out from right to left.
  6. HP Photosmart D110a LCD Screen Replacement: 步骤 6 中的图像 1,2 HP Photosmart D110a LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the fourth screw, which was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. HP Photosmart D110a LCD Screen Replacement: 步骤 7 中的图像 1,3 HP Photosmart D110a LCD Screen Replacement: 步骤 7 中的图像 2,3 HP Photosmart D110a LCD Screen Replacement: 步骤 7 中的图像 3,3
    • With a partner's help:
    • Have one person lift the hood 2-3 inches.
    • Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
    • Remove the hood completely.
  8. HP Photosmart D110a LCD Screen Replacement, Printer Hood: 步骤 8 中的图像 1,3 HP Photosmart D110a LCD Screen Replacement, Printer Hood: 步骤 8 中的图像 2,3 HP Photosmart D110a LCD Screen Replacement, Printer Hood: 步骤 8 中的图像 3,3
    • Remove the single T-9 screw from the hood's underside, as shown.
  9. HP Photosmart D110a LCD Screen Replacement: 步骤 9 中的图像 1,2 HP Photosmart D110a LCD Screen Replacement: 步骤 9 中的图像 2,2
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
  10. HP Photosmart D110a LCD Screen Replacement: 步骤 10 中的图像 1,2 HP Photosmart D110a LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Separate the hood pieces while keeping the black ribbon cable connected. Rest the scanner piece carefully to avoid stressing its ribbon cable.
  11. HP Photosmart D110a LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 1,2 HP Photosmart D110a LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 2,2
    • The LCD screen is attached to the piece of the hood with the glass shield.
    • Do not remove the small ribbon wire. While the LCD has two ribbon cables, only the larger one can be safely disconnected.
    • To release the LCD, locate the two mounting slots, and push the sloped slides inward to release the LCD from its slots.
  12. HP Photosmart D110a LCD Screen Replacement: 步骤 12 中的图像 1,3 HP Photosmart D110a LCD Screen Replacement: 步骤 12 中的图像 2,3 HP Photosmart D110a LCD Screen Replacement: 步骤 12 中的图像 3,3
    • Slide the LCD module downward to remove it from its holders.
    • The large ribbon wire from the LCD can be detached if needed.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G38
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 4,287
